Billing for outgoing/incoming international calls
Hi there! I have a question... I'm on the $40 monthly plan which has 300 Canada Long Wide minutes. So the question I want to ask is that does the 300 minutes include any time from international incoming/outgoing calls? Thanks for your help. Regards, Athar
Yes, both incoming and outgoing international calls count against your 300 minutes, Athar. On top of that for outgoing international calls there will be an additional fee 🙂 You can check how much per country here: http://help.koodomobile.com/coverage-long-distance-and-travelling/long-distance
Hi Athar, When it comes to receiving international calls, it will go against your anytime minutes during the day time and you can receive calls unlimited during your nights and weekends at 5 pm. As for making calls, you will be charged a long distance rate (at any time of day) as well as it will use your minutes during the call. You can add a long distance saver add on to help save money per minute. Hope that helps answer your question
When you make/receive international calls outside of unlimited window, it will use your anytime minutes plus international rate/min will apply. If you make/receive international calls dulling unlimited evening $ weekend, it won't use your minutes but international rate/min still apply. Add: International rate/min for outgoing
Thank You so very much Sophia, Daniel Gunn and Mayumi...
