Are calls after 5PM counted against the anytime minutes?
Are calls after 5PM counted against the 100 anytime minutes on my plan? If I reach the max 100 anytime minutes and make calls after 5PM is there a charge?
If you have unlimited evenings and weekends starting at 5pm then calls do not count against your anytime minutes. How ever if you are on an older plan and dont have unlimited evenings then they will count against your anytime mins. If you reach your limit then a pay per use (overage) charge would occur, however if yo uhave unlimited evenings there would be no charge to talk during that time.
Dennis wrote:
If you have unlimited evenings and weekends starting at 5pm then calls do not count against your ...
Unless you called outside of Canada, otherwise as long as you make calls to a Canadian number while in Canada you're fine. Just my two cents 🙂
