500mb/500min Plan or "Lightweight" Plan?
  • 17 June 2015
  • 7 replies
  • 58 views
Wondering why I'm paying $45 for the old 500mb, 500min plan when the new "Lightweight" plan is only $38 and is essentially the same thing...? I use like 10 mb data so I essentially don't need it atm, is there any way I can save a cpl bucks by opting out of data usage?!
I f you want to take advantage of the new plans f you need to pay off your existing tab balance
Once you do, the new plans will be available to you
Hi Matthew. Chad, Bob, Sophia, Melissa, Ahmed, Dennis, Ahmed, Dennis, Mathieu and others can explain all the ins and outs of the programs to you. I can't. I can only tell you what I did. I was on the monthly plan, I think $36 or so for 200 MB and 200 mins, BYOD. Like you I found that I was using a bare minimum of both. (you didn't say how many mins you use) I switched to prepaid. I got the base plan for $15, (which gives you unlimited texts) 500 minutes for $25 and 500 MB for $20. They threw in the sim ($20) so my initial bill was $60 plus tax. I got 100 extra mins and 10% of the base of $15 a month for auto credit card payment and the unused minutes and data roll over every month. (Which I like.) When they get low, you just buy a new booster. The $1.50 off per month accumulates and when you have enough you can use that for boosters (as I think Sophia told me). So like Chad said if you can see your way to paying off your tab, your options open up and prepaid might be another option for you. You have to do the math for yourself to see what you can save and still suit your needs.
Hi Matthew. Chad, Bob, Sophia, Melissa, Ahmed, Dennis, Ahmed, Dennis, Mathieu and others can exp...Sorry Rikkster and Jonathon 1, I don't know how I forgot you guys.
Hi Matthew. Chad, Bob, Sophia, Melissa, Ahmed, Dennis, Ahmed, Dennis, Mathieu and others can exp...Who is Melissa?
Hi Matthew. Chad, Bob, Sophia, Melissa, Ahmed, Dennis, Ahmed, Dennis, Mathieu and others can exp...Hi Chad, it should have been Mayumi. It was late when I posted that. My apologies to her.
Hi Matthew. Chad, Bob, Sophia, Melissa, Ahmed, Dennis, Ahmed, Dennis, Mathieu and others can exp...Fred is probably new and doesn't know all the MM's exactly by name, Chad. There is a Melissa: http://community.koodomobile.com/people/morbidbutterfly
Hi Matthew. Chad, Bob, Sophia, Melissa, Ahmed, Dennis, Ahmed, Dennis, Mathieu and others can exp...Well, I'll be darned.
