Yesterday I tried connecting to my wifi and it said turning on and then Error. I still can't seem to get it to connect.
Everytime I try to start my wifi it says error below and when I look at wifi settings, I cant see any wifi options from other houses. I've tried a few things already like dialing *#*#526#*#* into my phone to get the driver to load which apparently has fixed this problem alot but my phone deletes the number when I type the last * so I added it as a contact and it still didn't work. I also tried freeing up more than half my ram which didnt work either, so Im not sure what the problem is, I need help. Thanks
Have you ever restarted your router?
Shouldn't ever need to use any dial codes, unplug your router on your home wifi like Chad suggested and I guarantee it will work I have to do it every once in awhile.
No I havent tried that but none of the wifis come up so its not my router its the phone not recognising that there are any wifis availiable
Liam Buirs wrote:
No I havent tried that but none of the wifis come up so its not my router its the phone not recog...
Do you have the phone set to search for the right frequency or automatic in the settings menu for the wifi under advanced settings
Userlevel 4
Restarting the router can sometimes help as well.
Chad and I already said that Tyler 😛
Userlevel 4
*cleans glasses* GREAT SCOTT!!
