Will the new Ulefone Power work with Koodo
Trying to find out if the New Ulefone Power will work on the Koodo Network.
The frequency coverage is
GSM: 850/900/1800/1900 (band5,band8,band3,band2)
WCDMA: 900/2100 (band8,band1)
FDD-LTE: 800/900/1800/2100/2600 (band20,band3,band1,band7,band8)
It will be running on Android 5.1 and going to 6.0
Dual sim dual standby
Both SIM slots are compatible with 4G, respectively. When they work at the same time, only one of them can receive LTE service and the other GSM. You can choose in settings which one for 4G.
The device, as you posted it, isn't compatiable With koodo.
Thanks for your quick reply.
The information was from the manufacturers site.
Why Not , Lack of Band 5 coverage ?
Why Not...
Koodo has no 2G (GSM)
This device lacks 3G, HSDPA, UMTS 850/1900 & LTE Band 4
Why Not...
OK , Thanks Very Much ...  My search for a unlocked, Affordable phone with a great camera and high battery capacity running android 5 or better that doesnt cost a fortune continues. My Galaxy S3 thats still on Tab wont work with Android Auto or the other features of my New Car
Why Not...
What's your price range?
Why Not...
Under $300 or so
Why Not...
https://oneplus.net/ca_en A little out of your budget but worth a look.
Why Not...
Thanks , I'll order a One Plus X when i get a invite
Why Not...
Under 300 CAD high battery AND great camera? Hmm...perhaps the Sony Xperia Aqua M4. Not sure if the Moto G 3rd Gen would qualify (depending on your defintion of "great" and "high" but it's 250 CAD (240 with Koodo) new and generally an excellent device for the price. There's the Asus Zenfone 2, although the battery life is fairly average it is otherwise an excellent device.The Laser variant model is supposed to have an excellent camera and a 3000mAh battery and it's 280 unlocked.The Huawei P8 Lite is 320-350 CAD new. There's lots of Blu phones for 300 or less that could be good. You can also find a lot of last generation flagship or mid range phones on kijiji/ebay for 300 or less.
Why Not...
Oh I can second the Blu phones. I love my Win HD for traveling.
Why Not...
Will Ulefone Armor 2 work with koodo?
Why Not...
You'd have to check the bands. You're looking for 850/1900mhz for 3G and 1700/2100mhz ideally for LTE. 2600 will worknas well but not quite in as many places. 700 is also used but presumably for more rural areas and Koodo / Telus don't put up a coverage map for 700 or other bands.
Why Not...
Have a look at willmyphonework.net to learn about the phone's compatibility with the Koodo or Telus network.
Why Not...
I looked at willmyphonework.net but there they have only Ulefone Armor. I was wandering about Ulefone Armor 2. can you please check for me? here are phones stats: https://www.ebay.ca/itm/5-034-Ulefone-Armor-2-Smartphone-Android7-0-Helio-P25-6GB-64GB-4700mAh-Water...?
Why Not...
You can go into item description and it'll give you the bands it works with. Did you do that? You ought to always read everything before buying. In this case it does work.
Why Not...
According to that link it should be fully compatible.
Why Not...
Thank you. Can you also check this one and tel me if its compatible with Koodo?
https://www.ebay.ca/itm/Doogee-S60-Android-Phone-QI-Wireless-Charging-Octa-Core-6GB-RAM-Android-7-0/...
Why Not...
You can select item description and match up the bands with the ones I named that are needed. I can tell you yes, because it is, but it would really be ideal for you to see for yourself.
Why Not...
Ya im uber confused how this stuff works will the ulefone armor wirk with koodo
Why Not...
https://community.koodomobile.com/koodo/topics/will-the-ulefone-armor-work-with-koodo-the-armor-n-2s-as-well-please-n-thanks
