Will the Galaxy S7 edge be supported on your network? If so how soon?
  • 22 February 2016
  • 7 replies
  • 60 views
I'm planning on purchasing outright Galaxy S7 edge. Will this be supported by Koodo? I'm in Markham, Ontario, Canada
Yes. As soon as it comes out.
Yes. As soon as it comes out. As long as it's the Canadian version. Some U.S version may not work. But chances are that it will. And as long as it's unlocked or locked to Telus.
I have Galaxy S4. Do I need a new Sim for S7?
The S4 used a micro sim card, the S6 used a nano sim card, and presumably so will the S7. So yes, you will need a new sim card.
It would indeed be a safe bet you'd need a nano Sim.
Release date announced. It will be available at Telus for store sales in canada March 11th. Here's a link for reference.
http://www.androidcentral.com/where-a...
New Info on the s7. http://www.androidauthority.com/samsung-galaxy-s7-and-galaxy-s7-edge-lock-to-carrier-sim-676653/
