will my Samsung Neo phone data work on my Ipad
Samsung Neo 5 with an Ipad Mini 4
Hi, yes it will just create a wifi hotspot in the settings of your Samsung device and then connect your iPad to that wifi connection.
You may want to turn off auto updates and backups on your iPad. Those can eat up large chunks of data as your iPad will assume you're on home wifi.
