Will my G2 work at Koodo?
Hi I have LG G2 (F320, I actually bought it from Korea). And my phone's frequency is GSM/GPRS/EDGE 900/1800/1900 HSPA+21Mbps 2100 LTE Cat3 B5(850), B3(1800), B1(2100) Will my G2 work at Koodo?
No because it doesn't have HSPA+ 850/1900
Checking the specs for that model on GSM arena I don't think it will work with any Canadian carrier. Only one you might have luck with is Rogers/Fido but if you do you'll get 2G data speeds only.
If you want to use the G2, the model you'll want is D803. It has the proper 3G and LTE bands for Canadian carrier frequencies.
