Will I be charged anything for call during inter State travel.
Hi Debasis, what do you mean interstate travel? Do you mean travelling to the United States, or travelling through the province? Or something else completely?
If you mean within Canada from province to province, then you'll not be charged extra unless you call an international number or exceed your minutes during daytime. If you mean traveling in the US then you will be charged the same roaming rate regardless of the state you are in. If you mean nations internationally then you'll be charged according to zone and if you have a roaming add-on. It's always free to receive texts regardless of where you are. Receiving Cal's you'll be charged depending on location outside of Canada.
