Will a unlocked Samsung s6 G9208 work with Koodo?
It supports these LTE frequencies: 4G FDD LTE: B1(2100), B3(1800), B4(AWS), B7(2600), B8(900), B28(700) I know Koodo runs on B4, but I just want to make sure before I purchase. And I already have a phone with Koodo, and it uses a micro sim, so I just need to buy a nano sim and I should be good to go right?
Yes it should work with Koodo as long as its unlocked. And thats right, just purchase a nano sim card and switch sim cards via self-serve and then you're good to put the sim card into the phone and use it
Thanks!
