will a phone work on Kodoo GSM, 4G, 3G, GPS GSM+WCDMA+FDD-LTE 2G
will a phone with these networks work on Kodoo Wireless Connectivity WiFi, Bluetooth,
 GSM, 4G, 3G, GPS WiFi 802.11b/g/n wireless internet Network type
GSM+WCDMA+FDD-LTE 2G GSM 850/900/1800/1900MHz
3G WCDMA 850/900/1900/2100MHz
4G FDD-LTE 800/1800/2100/2600MHz phone is Mstar M1 Pro Android 5.0
It should work on 3g fine but LTE will not work properly
guess i don't know what that means coverage map shows LTE but koodo is only 1700 is that right
Some towers are 1700,some are 2100 and some are both. This phone will only work on LTE where there is a 2100 MHz signal.
thanks
I explain how everything works here : https://community.koodomobile.com/koodo/topics/unlocked-phone-compatiability
Hi Robert,  is there a website showing the tower locations and frequencies?  I'm in a similar situation thinking in buying a phone with these 3G and 4G frquencies support:
3G: WCDMA 900 / 2100MHz (Band 8 / 1)
4G: FDD-LTE 800 / 900 / 1800 / 2100 / 2600MHz (Band20 / 8 / 3 / 1 / 7)
http://willmyphonework.net/
Do you know whether this tool is reliable ?  I hate to have to ask for every phone ...
John wrote:
Hi Robert,  is there a website showing the tower locations and frequencies?  I'm in a s...
Try http://www.ertyu.org/steven_nikkel/cancellsites.html
Kiddos voice/text services run on 3G 850/1900. Based on the specs you're writing, that phone won't work with koodo.
ok,  thank you both
