wifi will not work on my cell
yes I recently a Samsung the model is sgh-s730m and for what ever reason it will no longer allow me to connect to the net using my Wi-Fi it did work at first and now will not let me turn on the Wi-Fi on the phone.
Have you tried pulling the battery and SIM card from the phone for about a minute, and then try connecting again? If it still doesn't work, it might be something wrong with the phone... back up everything that's important on your phone and then do a factory reset, restoring the phone to its out of the box state.
All that you have mentioned I did try and still a no go..think I will have to send away for repair, too bad the phone is only 2 weeks old.
Al White wrote:
All that you have mentioned I did try and still a no go..think I will have to send away for repai...
Does it happen with other devices, too? Or is it only your phone?
Userlevel 2
Call your ISP and see if there's a limit as to how many devices can be connected to your wifi connection.
