wifi will not turn on
Samsung Galaxy S4. Wifi will not stay on. When I touch the wifi switch, the slider goes to the right (on) position. However, after a few seconds, the slider returns to the left (off) position by itself. Tried rebooting but that didn't help.
Try factory resetting the device. I know a few people who had that problem and it was fixed. But its a process so back up everything. And then dedicate some time to setting your phone back up. Its easy just follow the instruction's Best of luck.
Try removing the battery.
You're not the only one. Here's a list of people complaining / trying to find solutions http://forums.androidcentral.com/samsung-galaxy-s4-active/294093-please-help-my-galaxy-s4-won-t-let-...
Thanks for the tip. First step was battery removal. Not successful. The fellow at the local Koodo kiosk transferred the data to a spare S4, then did a factory reset. Not successful. I took it to a cell repair shop. The technician there said it was a pooched motherboard. Replacement would be about $150. If that is the case, then I may be better off retiring it and going with a newer model.
Les wrote:
Thanks for the tip. First step was battery removal. Not successful. The fellow at the local Koodo...
I concur. I wouldn't spend $150 to repair a phone of that age. If everything but WiFi works, I'd keep it as a backup device, but I'd look to replace that phone. Most midrange phones available today can give you a better user experience than the S4, without costing an arm and a leg.
My s4 started doing this did the battery and it fixed it for a little bit... but now its doing it again.. thanks for the help
do not send me any of this koodo community forum
Click on your profile and disable e-mail notifications!
