Open the phone app
Go to the phone settings menu
Turn on the option for wifi calling
It should walk you thorough the process from there.
You may need to restart the phone once it says you are done.
If there is no wifi calling option or it errors out during the process, the phone may not be supported.
Thanks, there is no wifi calling option
https://www.koodomobile.com/en/help/wifi-calling
Thanks
I have another phone samsung A5 and it works
Hello there! Can you send us a private message on Facebook https://www.facebook.com/Koodo so we can authenticate the account and check the phone number? Click on the message button.
Login to the community
or
