why won't my nexus 5 work on koodo?
I just got my nexus 5 from the Google playstore after being told on this forum that it would work. When type in my ime to check if it is compatible it says it's not
Idk but it is
Put your SIM card in it. It will work. The IMEI compatibility checker is near useless.
OK I don't have a some card yet getting one soon! but would a prepaid sim work?
Yes, Koodo also sells the phone so it's compatible with all of their services.
