Why I don't have volume?
No volume
Are you connected to a bluetooth device? Are your headphones in? Is your volume on mute? What Android do you have?
No blue tooth a ll volumes are up
Press and hold the power button until the power menu appears. Make sure silent mode isn't selected. It's on the bottom left and looks like a sideways bell with a line through it. What phone do you have and what can't you hear ? Music? Calls? Both?
Moto e andci don't have volume at all I get no notify ring I am missing phone calls
Moto e andci don't have volume at all I get no notify ring I am missing phone calls Are you able to make a phone call? Did you try the suggestion I made above about silent mode?
Moto e andci don't have volume at all I get no notify ring I am missing phone calls Yes about phone call my phone is not on silent mide
I have checked there should be sound
Mode
In settings...Make sure notification sounds are on.
Yes areso that is why I do not understand
Are you using any of the Moto Assist features?
Hi Brae, is your phone working fine now? Keep us posted!
