Where can I find the pay per use intl long distance add on for 0$..
I am trying to find the pay per use intl long distance add on (0$), I've managed to find the intl data roaming add on and intl voice roaming but can't seem to find this add on that it says I need..where can I find it? Very detailed instructions would be appreciated!
1 reply
This is a feature built into your monthly plan add ons already. If you look at your plan details, you'll find its already there. If for some reason it's not there then it may have removed in the past to prevent international long distance calls. You'd need to contact koodo via Facebook messenger or Twitter direct message and ask them to add it again.
