Voicemail speak when leaving msg
When someone leaves a message, they have to listen to a load of options. I cannot find an option to disable. Does it exist?
Do you mean afterr they leave their message?
When the voicemail picks up, it says your "greeting" and then says to "leave a message after the tone, when you are done press # for more options or hang up". If you're talkinng about that, it can't be disabled. If you're talking about something else, you'll have to be a little more specific
