Voicemail number!!
  • 14 May 2015
  • 8 replies
  • 1028 views
I have koodo prepaid, and today I had new voicemail notification, when I try to open that I'm having this message box, "Missing voicemail number" No voice mail number is stored on the SIM card. And I have the option to add a number, so what number I should enter there?
Thats wierd, i would recomend calling customer care by dialing *611 from your phone to have your voicemail reset
Userlevel 3
Thats wierd, i would recomend calling customer care by dialing *611 from your phone to have your ...weird*
I had the same problem today and this is what I had to do because I hadn't set it up yet. In case you haven't here is the link. http://help.koodomobile.com/prepaid/calling-features/how-do-i-check-my-voicemail-on-koodo-prepaid
Wrong link I think. See if this works better http://help.koodomobile.com/SearchResults?Search=how%20to%20set%20up%20my%20voicemail%20service
Sorry that takes you to the features page try http://help.koodomobile.com/SearchResults?Search=how%20to%20set%20up%20my%20voicemail%20service and then click on where it says click here in blue.
Try adding 1+whatever your 10 digit cell phone number is This should take you to your voicemail and then enter your password and go from there
Thank you guys, Dave I did +1(my number) and it works, Thanks.
I have the same problem as you, but even I did 1+my phone number, it showed“ change your voicemal unsuccessful" .
