Voicemail just starts recording when ringing stops with no warning
  • 29 March 2013
  • 3 replies
  • 13 views
No voicemail recording (Hi, im busy, leave a message) it just stops ringing and starts recording I was wondering why I was getting strange voicemails from Indian dudes, but now Im assuming that it's just telemarketers (non english ones?) just talking into it cause it sounds like someone picked up
Hi Jake, That's odd! Did you record a message yourself or did you choose the default one? You might want to go into your voicemail and check your settings... can you record a new message?
If you aren't using a default message, call in to your mailbox and re-record your message. Just listen to the options - it's there. If that doesn't work, try one of the default messages and see if they work. Sounds like your recorded message just didn't get saved...
Hi there, if you're still experiencing problems with the Voicemail, give us a call and we'll reset everything. We can be reached at *611 from your cell or 1-866-995-6636, option #6. Thanks!
