Using Québec no. In alberta
  • 23 February 2018
  • 7 replies
  • 22 views
Hi im with unlimited making calls and texting all over canada just curious to know if im able to use this facility in Alberta as im moving there? Pls guide
Texts, yes since they are canada wide.
If you have Canada wide calling when in Quebec, then yes you can make and receive calls in Alberta without issue
Note that you may have to switch to an Alberta plan in the future.
Note that you may have to switch to an Alberta plan in the future.Only if you switch to an Alberta number
Note that you may have to switch to an Alberta plan in the future.Oh okay, the nitty gritty says otherwise, or is just vague with the details. "Rate plan available for Quebec residents with Quebec area codes only. Subscribers moving to another province will be transferred to an applicable rate plan for that location."
Note that you may have to switch to an Alberta plan in the future.If you dont change your address or phone number, no one will know 😉
Note that you may have to switch to an Alberta plan in the future.You beat me!
Note that you may have to switch to an Alberta plan in the future.The voice of experience: one couple I know moved from QC to ON three years ago. He kept his QC number & plan, she switched to an ON number & plan, so between them they have a local number for both sides of the family to use.
Plan and billing goes with the area code of the number.
