Using a koodo galaxy ace sim card in a telus iphone 4?
hi! I recently bought a iphone from someone and I was wondering if I could take my sim card from my galaxy ace and cut it and put it in the telus iphone if it would work?
Yes it would. You may have to update the carrier settings via itunes with the Koodo sim in the iphone 4, but it should work. I would also recommend just buying a micro sim for $10 instead of cutting the sim, but if you want to save the $10 that is up to you
Here's a good tutorial! https://www.youtube.com/watch?v=gVqRRLVHtfk You could also buy some cutters to do it for you. This is what I did for my macro>nano SIM
