Usage history for airtime-calling my own number??
  • 3 September 2015
  • 803 views
Ive got a question,if somebody could give me an answer pls...-when i viewed my usage history for airtime ive got a history of a call which appeared to be my own mobile number,its like im calling my own number?how did it happen?pls answer thanks
I did a little searching around in the community and this is one explanation given. "Some numbers are not posted on your bill when you receive a call from them. Lacking any other number to post, the system just posts your own number. I can't say exactly why it's your own number, but it's always been like that. I think they just haven't bothered to change it because it'd be confusing no matter what they put". https://community.koodomobile.com/koodo/topics/my-bill-shows-that-i-called-my-own-number-and-talked-for-6-minutes-is-that-possible
Calls from "private numbers" are often posted as being from your own phone number. Experienced this as both wife and I have private numbers. Calls from one to the other report as a call from self.
Incoming calls are posted as your own number on your bill so it could be that too
Could it be voicemail too?
Hi there, Dfbutt is right! Incoming calls from private numbers will be displayed with your own number on your airtime history online. Thank you!
