USA Incoming Call to landline then call forward to my cell
I currently has unlimited Canada Wide talk plan.  Want to Call Forward my office landline to my cell.  If the incoming call is originated from USA, will that be consider US long distance call or Canada call because my office phone is a Canada number?
Thank you,
Connie
it will be treated as a normal incoming call. Where the call originates does not make a difference in receiving on your cell phone.  Depending on how your plan treats incoming calls will determine how you are billed.
Daniel Hryb wrote:
it will be treated as a normal incoming call. Where the call originates does not make a differenc...
All incoming calls are treated equally regardless of origin [i]as long as you are physically located in Canada. There is no long-distance surcharge, and the incoming call will display the originating number on your screen as it rings thru.
