US roaming add on not working
I just went over to the US today, bought the 30ALL plan so we could have some data on our honeymoon . Unfortately it isn't working at all, can only connect while on wifi. Hoping for an answer/ideas to fix it or a refund if it isn't going to work 😞 I'm on a Motorola z play
Are you connecting to a carrier at all or does it say no service? Have you tried restarting your phone?
Allan wrote:
Are you connecting to a carrier at all or does it say no service? Have you tried restarting your ...
Restarting didn't work 😞 connected to at&t
Oh! Figured it out, was missing a setting. Thanks!
Care to share your solution so someone else can benefit?
Data roaming was off?
Says I'm connected to at&t, able to send texts
I'll try restarting
