unlocked android mms
  • 30 October 2014
  • 1 reply
  • 2 views
Unlocked android, mms not working. Data is on, apn settings for data are correct enough that everything else is working fine...what am i missing?
Best answer by Sophia 30 October 2014, 01:33
Did you check your APN settings for MMS as well? http://aide.koodomobile.com/Portals/0/Phones/PDFFiles/Android.pdf
1 reply
