Unlimited incoming or Unlimited Canada wide?
My plan has 200 any time minutes, my daughter (bell customer) and I talk everyday (not local). She always does the calling and not always after 5. Needless to say 200 min isn't enough. What add on would best suit. Unlimitied incoming, or unlimited Canada wide. Really just need some kind of extensions for her calls.
Hi Patricia,
You can get the 10$ add-on that gives you unlimited incomming calls, with this you wouldn't have to worry about your minutes whenever your daughter calls you!
Will that work even though she is not local? Still Ontario but not local.
That is correct. It will cover any incoming call regardless of where it came from.
Thank you both!! Much appreciated.
You could also convince your daughter to join Koodo. 🙂 We will even reward you for it. https://referafriend.koodomobile.com/public/home.pg?lang=en
And if you and her are on the same account you could have unlimited nationwide calls without having to buy any extra add-ons.
