Unable to make calls problem, Samsung S3
I have a Samsung S3 and for the past couple weeks, at random times, I noticed I cannot make any calls. As soon as I press the "call" button, I get "call ended". When I restart my phone, it works but then stops throughout the day. What could be the issue??
I'm not too sure. Maybe you could try a battery pull which is taking out your battery and SIM card for 30 seconds - 1 minute and then putting it back in and restarting the device. Also, are you on Koodo Monthly or Prepaid? If you are on Prepaid, maybe you have no more talk boosters left on your account and need to top up and buy some more? If all fails, you could always go to the nearest Koodo shop and ask for assistance. If it is under warranty, you can get a replacement device since it isn't physical damage.
John Lee wrote:
I'm not too sure. Maybe you could try a battery pull which is taking out your battery and SIM car...
I just tried pulling the battery out for 1 minute and it worked!! Thanks John Lee.
Same for me when I switched from Bell to Koodo. The fix was to disable the LTE. Found this sollution. 1. Disable LTE While the phone is powered on, remove its back cover and eject the SIM card. The phone will prompt a restart once it detects the absence of the SIM card, so simply restart it. Once the device is powered on, dial *#2263#. Choose WCDMA and WCDMA All. Put back the SIM card to its slot. Reboot the Galaxy S3. http://thedroidguy.com/2014/03/solution-samsung-galaxy-s3-receiving-calls-86843
I'm on a monthly plan, never had any issues. Also the problem is only with outgoing calls, it disconnects as soon as I hit the call button. I've always been able to receive calls, send text messages and everything else. I was told to clear my phone cache see if that helps, or maybe there's something wrong with my sim card? Do you know if I would get a replacement free or charge?
Kat wrote:
I'm on a monthly plan, never had any issues. Also the problem is only with outgoing calls, it dis...
You could ask but SIM cards are consumable items. If it happens too often after replacing it then something's wrong with the phone, methinks.
You will probably need to pull your battery and your sim card leave it out for 5 minutes and put it back it. This will reset your phone to the tower most frequently used.
trust me i have tried and it only works for a short while. the only way is to click the airplane mode on and off again.
Do you have the proximity sensor set to turn the display off when you place the phone to your head so you don't hit anything including the end call icon with your ear. Make a call and place your hand covering the top part of the phone where the sensors are the ear piece, if the display doesn't shut off go into your settings and make sure your proximity sensor is enabled.
I'm having the same problem. It's happening at multiple locations, and I always have 4 bars (signal strength) when trying to make the call. I have to restart the phone to make outgoing calls. This happens a couple times a day now. My phone display does turn off when I hold it to my ear, so it's not because I'm accidentally hitting the 'end' button. I've been googling this and found alot of people with different carriers are having this problem. I haven't found the cause or fix for this problem yet.
I have this problem as well and have been since i got the phone (December 24th) after changing the sim card, factory resetting the phone, getting a new phone from Koodo the issue still persists with my new phone, Apparently it's caused by the Samsung update that was done in December. The only fix that works is enabling flight mode and then disabling it....it's ANNOYING but it gets it working until it decides to act up again....it's a real piss off that's for sure.
I have the same problem brand new phone S3 and cannot make two call in a row when contacted the customer service they pretended they didn't know ...I this is the problem between Samsung Electronic and Koodos why are they giving the phone to people with contracts.........from January untill now I have not get a good service .
Winston G wrote:
I have the same problem brand new phone S3 and cannot make two call in a row when contacted the c...
While I do sympathize with your situation, is there a reason why you have not returned your phone for an exchange before the 15 day return period expired? I mean, if you had nothing but trouble with this device right from the start then why choose to keep it? You are more than free to seek legal advice, but it's very unlikely that it will be cheap or that it will work in your favor. The contract that you have signed is in no way against any Canadian laws or wireless regulations. You may, however, have a case against Samsung Canada but the fact is that you have not dealt with them yet. Your device is under warranty. I advise you to request a warranty repair from customer service. Be patient. The most that Koodo (or any other provider) can do is try to troubleshoot things with you here or over the phone, but warranties are handled by the manufacturer (usually through an authorized repair centre such as Flextronics in Newmarket, Ontario). Koodo will cover the shipping costs.
Virtual star Ivan Winston I don't know if Koodo pretended that there was not an issue with the S3 that made it inoperable as I had the Galaxy S3 for a full year and had not a single issue with the phone at all other than it was a slow device after awhile but nothing that made it not work as intended. I'm meaning towards user error in not understanding the UI or a setting that changed after an update ,if it was an issue Samsung would have fixed the issue ages ago they aren't Ines to just let an issue ruin their reputation with customers .
I am going to seek legal advice i think this is ripping off consumers and the CCTS /Government do nothing ..........why dont they give Verizon to come in the market since this is a problem they can fix ...
Winston G wrote:
I am going to seek legal advice i think this is ripping off consumers and the CCTS /Government do...
Yes because Verizon will be able to fix a Samsung issue with a specific calling function on their network. Although I feel your pain about having a device you can't fully use on their network, there isn't much Koodo can do at this point. Have you tried contacting Samsung explaining the situation and see what the status is? I feel like it's being looked into because several others here have reported it, too.
Are you trying to use a Verizon phone on Koodo or visa versa and its not working properly?
No I don't think so Paul, he mentioned a contract since December and having the issue with his phone since then. Then he wanted Verizon to come up here (surprise! They backed out) and they'll do some of sort of voodoo magic to fix a software issue with a device they didn't make.
I am sorry about your troubles. No doubt they are frustrating. I on the other hand have had excellent service from koodos. Better than the other guy...r...
I have now have a lawyer who is interesting in my care is there any one want join me.....
No, feel free to waste your own money.
Userlevel 4
Good luck with that. A lawyer won't fix a technical issue. By the looks of the previous posts, you have not returned the phone within the 15 days as mentioned by Ivan. Verizon cannot fix a problem that has nothing to do with them. There is always a fix for everything and if you refuse to do such fixes (worst case scenerio is getting a different phone) then the cost of a lawyer is all on you. Have you called Samsung yet? Based on your post, probably not. Again, I wish you good luck.. FYI - I highly doubt that the agent was pretending anything. I recently found out that the S3s that have 4.3 OS are the ones having the issue with calling.
Samsung electronics Canada is not address the problem for the s3 koodo is not finding a solution for its customers what is the next step then.. I have done all the thing you guys mention and no solutions the the problems
What, didn't find any takers for your lawsuit?
I have the same problem. Within 14days telus replaced my phone as everytime I drove outside the city I could not make a call. Phone replaced and now calls still end but if I reboot I can get it running again. Very annoying. Wish there was a fix!
Kathy-Lynn Merschel wrote:
I have the same problem. Within 14days telus replaced my phone as everytime I drove outside the...
Check which Android version you have, chances are you're probably running version 4.3. (to verify, go to Settings > scroll down to and tap About device/phone). There is the option of downgrading to an older Android version like 4.1.2. or 4.1.1. To give you an idea as to what's involved, I've posted a link that shows how to downgrade from 4.3 to 4.1.1. http://forum.xda-developers.com/showthread.php?t=2625461 Other than that, I haven't been able to locate a quick fix method that repairs the issue you're describing. The other option is to wait and see if Samsung comes out with an update that will hopefully resolve this problem.
