turn on phone after roam
how do I turn my phone on to kodoo network after roaming. I am using a LG phone.
It should automatically come back . You can try toggling the airplane mode on and off. You can also reboot the phone now that your back in Canada.
Userlevel 4
Sometimes it take a long time for the phone to come back automatically.
Sometimes I have to go in and manually select Koodo after I've been in the states. You can do that in your network options
