TMobile Note 3 on Koodo network
Will the TMobile Note 3 work on the Koodo network? http://negrielectronics.com/samsung-n900t-galaxy-note-3-32gb-lte-t-mobile-unlocked-white-open-box.html#.U7T3fPldWSo
If it is unlocked, it should work 🙂
Userlevel 4
Put the IMEI number in the empty box in this link http://help.koodomobile.com/getting-started-with-koodo/sim-cards-and-non-koodo-phones/how-do-i-know-if-my-phone-will-work-on-the-koodo-network
If your getting it from a place like near electronics I strongly recommend getting the unlocked international model, it will get updates months before the carrier branded models which is great when all your friends are still waiting for their update and you can rub it in their faces lol.
