The vibration setting on my samsung ace 2 has stopped working. How do I fix this?
I have tried a factory reset, that did not work. I have tried checking my settings, did not work. Any ideas?
Best answer by Dennis 23 June 2014, 17:21
Sounds like your vibrator died. If your phone is still within the 1 year warranty you can send it in for repairs (assuming no physical or water damage) http://help.koodomobile.com/getting-started-with-koodo/before-you-purchase/what-is-your-warranty-and-repair-policy
1 reply
