the data plan dose not work ......why?
  • 7 August 2015
  • 4 replies
  • 7 views
i have 100 mb plan , but dose not work on my phone though my phone is LG g3
Is this a koodo g3? Do you have data turned on under settings?
Under more networks/mobile networks/access point names select Koodo SP.
It's possible your apn settings were wiped from your. Phone check In networks, mobile Networks, access point and see if koodo is in there if not ull need the apn settings for it to work or data could be off
It's possible your apn settings were wiped from your. Phone check In networks, mobile Networks, ...thanks ...it is works now after i add tha koodo abn .
