Text messages won't send
Nexus 4 - Android is up to date. Removed SIM card and re-started twice. Text messages still won't send. Any advice would be appreciated.
Userlevel 2
Your data and voice working fine and only text that's giving you trouble?
Your data and voice working fine and only text that's giving you trouble?Voice is working fine. Data is working fine on wifi at home and when I am in a wifi spot i.e. Starbucks
Your data and voice working fine and only text that's giving you trouble?I have a new a5 have restarted 5 times. Sms wont send.. recieving intermittent msgs
Your data and voice working fine and only text that's giving you trouble?Data and calling works just sms.
Your data and voice working fine and only text that's giving you trouble?Did you previously have an iPhone?
Your data and voice working fine and only text that's giving you trouble?I did a few mnths ago. It was fown for a couple hours that i know of. I changed settings from 3g to 4 g or vice versa.. not sure but its working now
Your data and voice working fine and only text that's giving you trouble?Solution 1: Reset your phone
Solution 2: Reboot Your Message Notifications
Your data and voice working fine and only text that's giving you trouble?Thanks for the help but the last reply was 10 months old and the person said that it's working now. Theres no need to revive this thread.
Hi Henry, do you have 3g enabled on your phone? (WCDMA)
Hi Henry, do you have 3g enabled on your phone? (WCDMA)No my 3G is not enabled. It used to be.
You need to enable it since it's needed to use basic phone functions (text call). You need to disable mobile data and not 3G. It's not the same thing 😛
I never turned 3G off, this must have changed with an upgrade. Do I need 3G when I am on wifi at home as well?
I never turned 3G off, this must have changed with an upgrade. Do I need 3G when I am on wifi at...Hi Henry, 3G must be on all the time for calls/SMS/MMS, even on WiFi 🙂 Have a great day!
