Text from pcmobile to kodoo phone doesn't work
Hi, I tried to send a text from my pcmobile phone (iphone 6s) to my kodoo phone (samsung). But I wasn't able to send it to the number, it was refused to send it anyway. But it's still working with all other canadian or european numbers. What could be the problem? Thank you!
Is your Koodo phone recieving texts from other phones?
yes, it's receiving texts from others. it's also receiving my calls from pcmobile.
If your PC Mobile phone is refusing to send the text, then it's most likely a PC Mobile issue.
Before contacting PC, I suggest you reset your iPhone's network settings: settings > general > reset > reset network settings. You'll lose any saved WiFi passwords.
thank you. I tried to reset my network settings now (I've an unlocked iphone 6s), but it isn't still sending the texts. I'll contact PC Mobile.
The iPhone with PC Mobile shows that the text hadn't even been sent? Are you sending it via iMessage? Are you able to send it as regular sms through another texting client?
yes, it does.
iMessenger is switched off. i nee to look if there is another texting client
Thank you Titanium. I deleted the contact and set it up again and now it's working 🙂. Maybe the problem was the skype client...
