TCL10L has no notification sound
  • 30 January 2021
  • 1 reply
  • 36 views
When I get a text or email, There is screen message, but no sound. All volumes are turned up
Best answer by rikkster 31 January 2021, 00:40
When you touch and hold a notification on the status bar, there will be two options that appear “Prioritized” and “Silent”.
1). Select “Prioritized” to allow a sound alert for this app and subsequent new notifications.
2). Select “Silent” to mute all notifications for this app.
Other options. Go to Settings > Apps - select the Messages or your email client, then tap App notifications to see whether sound notifications are turned on or off for the app.
1 reply
