switching phone
Im curious about switching phones, i have a S4 on a koodo plan and am thinking about buying a koodo iphone. am i able to just switch the plan over to the iphone or do i need to pay extra? is it even possible todo so?
Best answer by Chad Burr 19 November 2014, 15:26
Certainly possible. Plan retention depends on what tab level you choose. If you choose tab small or choose not to use a tab, you can bring any plan with you for your new phone. If you use tab medium, your base plan must be 30$ or more. And if you use tab large then you must select a tab large plan. You also may need to get a nano sim depending on which iPhone you select. The new phone should come with one. You can transfer your service to the new sim via self serve. Or if you buy at a kiosk, the rep should do it for you.
1 reply
