Sim card - UNLOCK phone - left Canada for Chile
Is there something to let me know that my phone has been unlocked and is working fine? I bought a sim card and used the unlock code that they gave me.
SO does the non-koodo sim card work on yoru phone?  If so, then it's unlocked
If you dont get a message saying that your phones locked when you turn it on with a different SIM Card in it then it's unlocked and you put the code in correct.
Should be good to go then I also byte an unlocked doul sims card phone witch means I can switch between two numbers and mine works fine
What if i put in the new sim card but they didn't ask for the code at that time? Is it supposed to be unlocked automatically?
David wrote:
What if i put in the new sim card but they didn't ask for the code at that time? Is it supposed t...
DOes the sim work?  If it does, then it is unlocked
