Signal dropping
My phone keeps dropping to no signal and no network. Even when I have 4 bars! And even when I am in the middle of a call and have not moved. Why does this keep happenig? And I have tried restarting it. And turning it off for 10 min and turning it back on.
Best answer by David AKU 9 January 2017, 00:52
Remove & reset the SIM card to see if that helps. Else you may need to replace the SIM.
1 reply
