SGS5 on Prepaid Possible?
Can I use the Samsung Galaxy S5 sold here on Koodo Shop and use/activate it on their/your Prepaid plans? Thanks
It can be used on prepaid but the shop can't sell it to you for prepaid.
You can activate the phone on Tab S, M, or even No Tab option with 1 month on the $29 plan and then port out to prepaid, but that's the only way to get prepaid phones above $500 now. I suggest you buy it online from a reputable source/seller like Amazon or eBay, another carrier that allows outright sales, etc.
Jonathan I wrote:
You can activate the phone on Tab S, M, or even No Tab option with 1 month on the $29 plan and th...
I was planning on buying it from expansys but wanted to forego the hassle of figuring which phone build is compatible with which network. This way it is much easier. Would a rogers or bell phone be complicated to unlock for koodo? I read there are sims on ebay going for $10 which also carry a $20 balance upon activation. That might be more economical way to go about it.
