several calls are going right to voicemail ....they are not on reject list.
several calls are going right to voicemail ....they are not on reject list. They do not show in call list. What is going on? I can't miss calls! I have an samsung phone
How's your signal?
signal is fine
Try rebooting the phone
Try rebooting the phone without the Sim in it. So turn it off, remove the SIM, turn it back on without the SIM in the phone. Turn the phone back off, put the SIM back, and reboot the phone. See if this helps.
I have done that
I just did so will see if it works
thanks
thanks
Try sending yourself a text. That will verify that the network loop from and to you is in order.
You can't entirely rely on bars to show your signal strength. Go into your device settings and check status. Should give you a signal reading in -dB units for signal strength. You should have no problem if your reading is between -95 and -55. Any number over -100 will give you sporadic service.
i turned off, removed sim card and put back in and seems to be okay now.
In terms of signal the phone is doing this when it is in a usual location where I have no issues.
so it's just odd.
hopefully it is fixed
thank you
In terms of signal the p...
Glad it helped Jocelyn. Keep us informed if it goes back to not working.
