Samsung S5 SM-G900F with Koode LTE?
Hi, I recently bought a S5 model SM-G900F and according to the specs it supports 1700/2100 bands.................but my lte speed on my phone seems slow only topping 5mbps. Network/Bearer 2G GSM B8 (GSM 850 MHz), B10 (E-GSM 900 MHz), B13 (DCS 1800 MHz), B14 (PCS 1900 MHz) 3G UMTS B1 (IMT 2100 MHz), B2 (PCS 1900 MHz), B4 (AWS), B5 (US 850 MHz Cellular) 4G LTE B1 (2100), B2 (1900), B3 (1800), B4 (1700AWS), B5 (850), B7 (2600), B8 (900), B17 (700) Thanks
Does the device indicate an LTE signal? Settings, connection, mobile networks, network type. Should be lte,wcdma,GSM auto
well its only indicating a H+ which i think H+ = lte since its a international phone. and it is set to lte,wcdma,gsm auto.
Brandon Gee wrote:
well its only indicating a H+ which i think H+ = lte since its a international phone. and it i...
Nope, my wife's S5 will actually say LTE when it has LTE service. You may not be in an LTE area. Where you at (generally)?
My note 4 which I purchased from Koodo, shows LTE. I have flashed roms before and some uses different icons as well. Do you have the exact same model as mine, specifically G900F because there are subtle differences from what I read? http://www.ncix.com/detail/samsung-galaxy-s5-g900f-unlocked-89-94889.htm
The G900f is the European model while we have the G900W8 North American model.
So the G900F is not compatible with Koodo LTE even though the bands are correct?
According to gsmarena.com, the G900F is missing the 1700mhz LTE band. That would explain why you're not seeing LTE
Ya I looked that up just now, false advertising on the ncix.com site(which I bought from).
Same information found here: http://www.gsmarc.com/samsung/galaxy-s5/
You have grounds to get your money back for the mistake if you can't live with the speeds. Good luck fighting them.
Thanks
When in doubt, choose a model for Canada or at least AT&T.
Amazing.
