Best answer by Nabil Koodo
Hi Mike, Our HSPA network uses the 850 MHz and 1900 MHz frequencies while our LTE network uses 1700/2100 MHz. If this phone is unlocked, it should work fine, however for the LTE connection, it is always better to have both frequencies (1700/2100 MHz). Hope this helps. Thanks ________________________ If you see a good answer, give it a star.
