samsung S3
  • 24 August 2015
  • 4 replies
  • 13 views
How do you know if your phone already has a virus ? I know that mine keeps throwing up random ads and msgs. What do I do ?
In the google play store grab adaware. It's a great app that shows you what ad grabbers are already on your device and gives you the option to remove them.
In the google play store grab adaware. It's a great app that shows you what ad grabbers are alre...Thanks !
Most pop up ads come from an app you already have installed. When you download these apps it will bring up random pop ups and other annoying things. It took me awhile to figure out which it was to remove it and it stopped once it was deleted. Check your apps!
Most pop up ads come from an app you already have installed. When you download these apps it will...What should she look for in her apps? They don't tell you" hello, I'm causing ads to randomly appear" Adaware does exactly that, they have a database of apps that cause the ads, they pinpoint the app and help you remove it.
