Samsung S2X incoming calls
I am having trouble with incoming calls. The voice is all mumbled and can't understand a single word. The same happens when I call someone. But if I call using a VOIP software like vonage, it works fine. Please help address this issue. It is urgent and painful.
Best answer by Yannick 29 April 2013, 19:08
Hi Atul, it could be a network issue or you might be living in an area with poor reception. I suggest that you give our technical support a call so we can look into it. We can be reached at 1-866-995-6636 from a landline, option #6. Thank you! ________________________ If you see a good answer, give it a star.
1 reply
