Samsung J3 (2018) Compatibility
  • 19 April 2019
  • 3 replies
  • 72 views
Hello, would anyone know if the Samsung J3 (2018) is compatible with Koodo network? Anyone use one here for GPS with Google Maps?
Thanky you,
Bernard
It is, as stated here:
https://community.koodomobile.com/android-81490/budget-smartphone-compatibility-7793920
A budget phone, and data consumption $$ for mapping services seems contradictory. Have you looked to an app where you download maps ahead of time? I use Copilot, but others have recommended Here Maps.
MotionX is a good GPS tracking App, also not consuming data.
Yes David, one can simply download custom offline Google map areas, and doesn't require any data to be downloaded at all. Works great! :)
Bernard
