Samsung Galaxy SIIx doesn't have a LED light
  • 12 April 2013
  • 3 replies
  • 29 views
Hi guys, I thought the Galaxy SIIX had a LED light that would flash when a text message/email/phonecall is received. Mine doesn't, and I did choose this option in the phone's menu. Is there anything I'm not doing right? Thanks.
As far as I know since I have the same phone, there is no LED light to tell you when you have sms, missed calls, etc... But if there is, I hope someone could tell us...!
As far as I know since I have the same phone, there is no LED light to tell you when you have sms...No there isn't a LED Notification light on the Galaxy S2X. You can download an app that will use the display to show you when you get a notification by flashing a little symbol on the display., here is the link https://play.google.com/store/apps/details?id=com.studiozitto.iLED_EN
There's unfortunately no LED. You can however use an App to flash the Camera LED (like iPhone does) using an App called "flashME" from the Google Play Store.
