Samsung Galaxy SIII - Incoming calls go straight to voicemail
Samsung Galaxy SIII - Incoming calls go straight to voicemail - just switched to Koobo
what plan do you have?
Hi Ronald,  if by chance, you ported your number over to Koodo from another provider, the incoming calls may go straight to voicemail until the port is successfully completed, which can take from a few minutes to a few hours (and in rare cases a whole day).  If you did not port your number over from another provider, then I'm sure the others will chime in with other suggestions 🙂.
Reboot the phone.
And make sure Blocking mode is not set in your Settings
Hey Ronald, have you tried rebooting your phone as Dennis suggested? Do you still need help?
Keep us posted!
