Samsung Galaxy S7 to S8. Keeping same phone plan.
Hi there, I was wondering if it was possible for me to switch from the Galaxy S7 to the Galaxy S8 without having to change my current plan? I am a monthly customer, but I don't use a tab. I assuming it would be possible to do so if I just simply purchase the phone fill retail price and move the sim card from my s7 to the new s8 phone since they both use nano sim cards. Could anyone confirm this for me? I would appreciate it. Thanks.
Hi! If you purchase a phone outright, you can indeed simply swap your sim card over. Koodo doesn't care what phone you use on what plan. The only time the plan matters is if you want to purchase a phone via a tab.
Techjunkie wrote:
Hi! If you purchase a phone outright, you can indeed simply swap your sim card over. Koodo doe...
Thanks a lot Cory! I appreciate it!
