Samsung Galaxy S4 Battery Life
What's the best way to improve battery life on the Samsung Galaxy S4? I've turned off the GPS, bluetooth, and only have the WiFi on when at home or work.
Change your settings so that software updates and playstore updates are done manually And/or over wifi only
Hi Andrew, The best way I found to boost my battery performance on my S4 is to do a factory reset, especially after a few updates. Before I do a reset,my battery would be at 20% after 4 hours and after a reset its at 50% after 8. It is inconvenient as you loose all the data the phone had, but the gained battery life is totally worth it.
Another factor worth considering is the age of the battery. The S4 has been around for two years. If the phone was purchased a year ago or just last week, the answer to this question could vary. Over time, batteries will lose their ability to hold a charge. If you find yourself having to charge the phones' battery at a more frequent rate or that the battery rapidly loses its charge between charges, the battery will need to be replaced. On the other hand, if this is a relatively new phone, the suggestions that Ahmad and Mathieu have provided should work well. Keep in mind that after a factory reset, mobile data will automatically re-enable itself, make sure to turn it off. Lowering the brightness level manually and adjusting the 'screen on time' in standby to one minute are a few other ways to conserve battery.
