Samsung Galaxy S3 (SGH-I747M) - LTE/4G Network Data not working
So I bought a used S3 about 3 weeks ago and I unlocked it with at a local shopping mall. I got my old contract on it and it worked perfectly fine until yesterday. I installed Cyanogenmod on it because a friend of mine recommended it for me. After having played around with the installed software (didn't encounter any problems whilst installing it) I decided that I liked the stock OS better so I downloaded the stock file (JellyBean 4.3) and I reinstalled my backup on the device but I am now having a big issue for me: I cannot seem to be able to active the Network Data, I use it a lot and it is really bugging me. I think I might have installed the "Telus" version of Android JellyBean 4.3 but remember reading that it was compatible with Koodo Mobile and their networks. Help?
Do you have the correct APN settings in the phone?
After some research I realized that I had to add one since it only gave me two Telus APNs by default. These are my settings:
Proxy is incorrect. Make sure these are what you have in your phone and try again: Name: Koodo SP APN: sp.koodo.com Proxy server: 74.49.0.18 Port: 80 Username: Password: Server: MMSC: http://aliasredirect.net/proxy/koodo/mmsc Proxy server: 74.49.0.18 Port: 80 MCC : 302 MNC : 220 APN type: default,mms,supl
Proxy is incorrect. Make sure these are what you have in your phone and try again: Name: Koodo...This helped me with an LG G3, thanks!
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for connection and now I see a "4G" icon instead. I heard that they are the same but I just want to make sure. And if not does it just vary from where I am? As I heard some regions don't necesseraly get for example 4G connection but only 3G. Thanks in advance!
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...Yup, some areas don't have LTE yet... But if you were getting it before and now you don't, just do me a favor and check your network settings. You have to make sure it says WCDMA/HSPA/LTE. I'm pretty sure I gave you the APN type needed to get LTE as I had this issue with my Koodo S4 mini using it with my Telus plan so just wait it out a little bit.
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...I read a bit around the webs and learned that 4G is basically the same thing as LTE (with some minor differences). And yes my WCDMA/HSPA/LTE setting is checked, therefore I'm guessing the stock OS that I installed shows "4G" instead of "LTE".
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...It's possible, but phones will usually display 4G and LTE as separate things.
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...Maybe there is another Proxy server for LTE? I don't know, just guessing...
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...Nah, it's the same one. I think it's the APN type. Try putting in blank and see what happens, then look at this and see if I was right, because this worked for the S4 mini I had on Telus (same network as Koodo) http://forum.xda-developers.com/showpost.php?p=34375750&postcount=5
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...I have the samsung galaxy s 3 and i get 4g and sometimes it shows Lte as well, maybe where i am from time to time, butno difference.
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...If I leave the APN type blank, 4G still appears, sometimes drops down to 3G and H+.. I also tried "Internet + MMS" and "internet + mms" these two would not work. I have also attempted "default, mms" and "default, mms, suppl" and these two were varying between 3G, H+ and sometime goes up to 4G. Overall my observation are that for my phone, "default, mms", "default, mms, suppl" and a blank APN type work and I'm guessing that they will all work with 4G and LTE and that I simply need to be in a LTE-enabled zone. P.S.: What is H+? Never seen this before!?
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...H+ is up to 42 mbps.
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...thanks!
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...how can i active 3g connection in this phone?
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...sgh-i747
Wow! Thanks a lot it fixed my problem! One question thought: I used to have "LTE" icon for con...My s3 can only get edge connection. Any idea how to get lte or just the H connection?
*#272*Phones IMEI Here# <<-- Csc Sales Code here u fix dial from phone
I have s3 i747 in pakistan its 3g is not working plz anyone help me
I have s3 i747 in pakistan its 3g is not working plz anyone help me If it's a Koodo phone, you have to enable Pay per use International Roaming for anything to work there at all. You can do it on self serve, or *611.
So I Just went through this, and I can get 4G (and LTE) now. But it still doesn't seem to want to let me do MMSes. Any thoughts?
Hi there, I just got a Koodo plan and I have the exact same problem as Dan - MMS'es don't work. Data works (same phone). What is going on?
